Metal box sticking out of plaster
30 Mar 2015
So let me get this out of the way…
The main builder suggested that there was no need to chase in the 35mm metal boxes as the wall will be plaster-boarded and skimmed. There was also a kink in the wall that worked in my favour. Despite this, I chased them in slightly.
Plastering done, all boxes are okay, apart from one. This sticks out by around 4mm and on one side. The builder and plasterer are two different tradesman for what it matters.
The style of switches is undecided. It’s possible, they have a lip which saves the day.
If not what are my options, other than ripping out the current box and surrounding plaster?
Thanks in advance.
3 options :
a) sink box further into wall
b) leave as - is and leave it as an example of sh*t trade work
c) build a surround around it as a 'decorative' feature
Sink it further in.
Not really a big job to do
If it was me, I'd cut round the box with a multi-tool (avoiding cables) and genttly tease the box out.
Chase the wall accordingly, and tease the box back in.
Or, once the box is out, put a 25mm box and use longer screws, if you think you will cause great damage.
Can I use a multi tool with a metal blade and cut the edges off so they are flush to the plaster?
I imagine grinding the edge of the box off will disturb the round knockouts, and the corners where the two sides are held together.
Never seen anyone attempt this, liable to do more harm than good.
Should be easy to remove the whole box if it's only dot and dab.
