Is it too much of a faff for sporadic DIY use, though? My first multitool (the original Fein, bought in the mid-1990s) came with an Allen key mounting and I was happy enough with it - possiblhy because there was no alternative available (in fact there was the Fein, or nothing).Allen key blade changes on a multitool would be a deal breaker for me, too much faf.
The one i linked to was for my dewalt, and also works with other makes, BUT do call them and check which set you need for your particular make when you have purchased,will have to buy one of those!.
combination drill - with a normal chuckdrill+driver
Does the extension still do that if you pull back the metal collar as you push it in? I don't see why it won't fit, that said, you need to use impact bits in an impact driver. Regular bits might break in an impact driver.
https://www.amazon.co.uk/impact-driver-bits/s?k=impact+driver+bits
Yeah, if I don't pull back the metal collar when I push the extension in, it will just pull right out again. I uploaded a video here showing how loose it is when inserted properly.
https://youtube.com/shorts/NHuvOt53DXQ?feature=share
