As Nest takes care of both the time and temperature control functions, no room thermostat is required. However, if you don't insert a link to join together the 'Live' and 'Switched Live' room thermostat terminals at the wiring centre, the wiring will be permanently 'open circuit' and the central heating won't operate.
I can't remember for sure which two terminals from the block below they are....
....but the diagram / nomenclature inside the lid of the wiring centre should tell you. I think from memory that it's 1 & 3, but make sure you check first.
EDIT:
There you go, it is 1 & 3.
EDIT:
