Hiya,
Would you expect the light in this room to be on or off (assuming a single switch in the UK)? ...and is there a standard?
We've previously had ours as down to be on, and up to be off. However, we've had some work done to rewire the house and the switches have been fitted the other way round (Up is on).
I've read that the UK standard is to have down as 'on' (apparently it's the opposite in the US).
Just trying to work out if I need to just accept there is no standard and to accept it as is, or if it is wrong and I need to ask to have them adjusted. I assume it would just be a case of swapping switched terminals?
We had the old switches for about 10 years, so it could just be what I'm used to?
Thanks in advance!
Thanks in advance!
