ok guys, ill try to make this sound as easy as possible.....i have a single light fitting in Living Room ceiling operated by 2 seperate 1 gang fitments (1 gang 2 way units)....
Removed the 2 existing fittings.
They BOTH have 3 wires (Black, Blue and Yellow) coming from the wall fitting (fairly modern house). And there is existing earth connections (Yellow & Green) fixed to the casings (these are thicker sleeves). The 3 RBY wires were going into the old switches in the following order:- Red to L1, Blue to L2 and Yellow to C.
Replaced same with the new fittings. The new units had exactly the same markings (i.e. 'L1', 'L2' and 'L' (the 'L' marking is the yellow or grey according to fitting instructions)). All connections were good and tight.
I can get one of the new units to work but the other new one wont. I removed the new one that didnt work and replaced it with old switch unit. The old one wont work now either! This tells me im maybe doing something wrong with one of them? Ive replaced loads of theses switches in the past with no problems. Thought it would be a 10 min job as well !!
What im i doing wrong?
Cheers
Mike
Cheers
Mike
