The bottom of my 22 year old double glazed aluminium rear door catches the metal frame when it closes. And my UPVC front porch door, which has the same type of hinges, needs realigning. What are these type of hinges called. If they are adjustable, how is that done. Any tips would be appreciated.
Thank you....I'm guessing your comments suggest there may be some way of adjusting the hinges concealed behind where the edge of the door and the door frame meet. If so, could you give me bit more of a clue...and what are these type of hinges called please.
The hinges I've come across tend to have some cover that pops off or a grub screw comes out, so you can hinge a plate open to reveal adjustment screws. So if there's nothing on the outside part of the hinge connected to the door frame, what about the part connected to the door?
