I’m looking for some advice on whether to get a new combi boiler or keep our current boiler and get an unvented cylinder.
We have just moved in to a new house. 1930’s dormer bungalow and a a gravity fed vented hot water tank (in the loft). The boiler is an Alpha CD18R (18kw). This is in the garage and seems to work ok (was installed in 2016) and is controlled by a Hive thermostat. The boiler is about 82% efficient and does it’s current job ok. The boiler seems to be a heat only boiler. However it may be possible to use with an unvented cylinder.
The cold water (apart from the kitchen tap) is off the cold tank in the attic and the pressure isn’t great. Toilets take about 10 mins to refill (might need some new fill valves). The HW tank is very small about 100 litres or so) not measured it so not sure if the exact volume. There are two bathrooms but the upstairs one has an electric shower (good mains pressure).
Bad points (current setup)
Hot water pressure very low in kitchen tap (this might be fixable with low pressure tap but not sure).
Not great pressure in the mixer shower.
Hot water runs out frequently (we have 2 small kids) due to small tank
Water too hot in tank sometimes (may need to adjust the boiler thermostat)
Low pressure on toilets etc.
We will at some stage look at doing work on the house which may mean the tank in the the loft is relocated. However, this might not be for a couple of years. As we might just build a single storey out the back. So TBC.
I have a number of options
Option A
Live with the system for now. Maybe try and improve kitchen hot water pressure (low pressure tap) and change the cold water to mains (might lead to issues with the shower mixer).
Option B
Swop out the gravity fed system for an unvented cylinder. The current tank is in behind the shower which has an aqua panel which could be taken out and replaced easily enough. The cold water tank and header tank would be taken away etc. As far as I’m aware a heat only boiler will work with an unvented cylinder?
Option C
Replace the current boiler with a good quality combi (looking at Worcester Bosch Greenstar 8000 30/35KW). Not sure what the house layout will be in the future but we could add an unvented cylinder to run off the boiler in the future. However, for now the combi would be more than adequate.
I reckon keeping the existing boiler and getting a unvented cylinder would be around £2K (depending on the type of cylinder). The new combi would be £4K plus.
Cylinder only is cheaper but may have to move it again in the future. New combi might be a neater solution but a lot more upfront.
I’d appreciate any thoughts or suggestions on the above.
Option A
Option B
Option C
