Removing concrete around cast iron/clay rain water pipe
30 May 2021
Hi all I have some old rainwater pipes from roof to below ground. I would like to remove the concrete ground around the rainwater pipe so I may lay some paving slabs
Whats the best way to do this without cracking the pipe
I have access to a electric breaker.
Start from the greatest distance from the pipe and work you way in. Never allow the tool to pressurise the concrete immediately around the pipe. Work slowly and don't get too greedy. Plastic fares better than clay in this instance.
Disc cutter and cut the concrete close to the pipe? Then use the breaker. The cuts will mean the vibrations are less likely to damage the pipe and then do as Noseall describes?
Thanks, in the instance I do end up cracking the clay pipe, what is there some way I can repair it. I.e cut out where is cracked and have some sort of adapter inbetween the two sections of pipe
Yes, always. No dramas. If however any foreign objects end up falling in and blocking the pipe much lower down.....woe betide!
