- Joined
- 22 Jun 2022
- Messages
- 17
- Reaction score
- 0
- Country
Ok I am after a little bit of advice, I am looking to swap over my light fittings (photos below).
I wanted to check if what I plan on doing is correct and yes I know to switch off the electricity before doing anything!
The two blue on the left:
Cable 1: Leads to the light fitting
Cable 2: From ceiling to the light fitting (in old and new fitting)
The two brown on the right:
So these four cables makes sense to me.
Its the loop cables in the middle which throws me off, I have checked all 6 light fittings and the loops are setup differently (I have no idea how these work) so I don't want muck around and break something.
Existing light fitting:
New light fitting:
To handle the loops this diagram below seems to indicate I need to terminate them and then just leave them in the fitting doing nothing.
So from what I have described would I be doing this correctly? The main bit is the loops which through me off, moving the live/neutral connection from the old to new fitting seems simple enough, but am I doing the right thing with the three loop cables? Some of my other fittings have 1 loop cable fitted, others have none, so im not sure if I need to use them or not?
Can someone advise me on this please?
Thank You!!
www.practicaldiy.com
New light fitting:
Thank You!!
Looped-in lighting wiring - the ceiling rose
