- Joined
- 29 Nov 2008
- Messages
- 350
- Reaction score
- 29
- Country
Hi all
Whilst I wait for a heating engineer to be able to fit me in do you have any thoughts on this?
I have a combi Saunier Duval F24 or F28 I think. Yes I know its a shìt make but I inherited it with the house and to be fair I've had zero issues for the last 6 years. Pressure is fine at 1.2bar.
The hot water has stopped working (just runs cold) and the boiler fires and then goes into error. Various codes showing from F4 to F13. If i reset the boiler and run the hot tap again, the same happens.
We are not using the heating this time of year but I've noticed if I reset the boiler and turn the heating on for 5 mins, then turn heating off, then use hot water it works fine, no errors, no lockouts. It worked for well over a week since doing that without further intervention and then it happened again. Same trick of turning the heating on and off has worked again......
Any thoughts?
Any thoughts?
