Good day to all.
I am new to the forum!
I have a new modular on pilings. The skirting is 2 inch rigid foam insulation in 4 ft pieces, coated in stucco. The gaps are just the textured surfaces touching and maybe up to an 1/8 inch gap. Last year was the first winter. It works well. There were no freezing issues. Coldest was -5, it averages higher, but on a cold day (-30+) with a good wind, there is enough air transfer to drop 5-7 degrees under the house with a few good gusts.
I was thinking the double bubble reflective insulation would be easy to work with. It would create a vapour barrier. Likely be easier to install than a floppy piece of poly and it would offer a reflective surface to reflect light when working under there.
My question is will it offer any real R value over poly?
The skirting is in a channel on a treated 2x4. There will be a 3/4" gap between the bubble insulation and the back side of the skirting. Writing this I wonder if the gap would provide insulation if the back of the skirting was sealed with poly and then the bubble insulation might actually offer some R value.
I was also wondering if I should use acoustic sealant or other goop to seal it to the ground vapour barrier and underside of the home, further stopping drafts. Or, will it react/dissolve? There are 5-7 thermally controlled vents that allow air transfer even when closed (not air tight), so there is no worry of completely sealing off the area if I go to town. Just not sure if other than looking neater, and possible longevity, if there is any benefit of the bubble insulation over poly.
Any experience or thoughts to share?
Thanks!
Thanks!
