- Joined
- 24 Jan 2019
- Messages
- 121
- Reaction score
- 0
- Country
As you can see I have a 22mm gas pipe sticking out of the ground. Such is its height, and distance from the wall that I either need to cut a hole in the new kitchen cupboard to accommodate it, or get the pipe shortened. I imagine it could be done but would need a specialist to rethread it, equalling £££s. Is it possible/legal to have it cut shorter and then joined to 22mm copper by a compression fitting? I.e. less £££s charged by a fitter for a job taking less time. Reading on here it seems that compression is ok for gas as long as it is accessible. Does the void under a kitchen cupboard count as accessible? Cheers.
