Wow, didn’t that thread go on…
www.diynot.com
Anyway, people are going to disagree, but I found a few cures for this problem, the first is the most radical:
1 Stop breathing:
Yes, if you stop breathing the relative humidity will drop, and it will be harder for the condensation to form (because it would need to be cooler).
2 Turn up the heating:
Discovered this one by accident! If you turn up the heating the relative humidity will drop. The automatic assumption is that this might make the problem worse, because it is probable that real humidity (ie the actual water vapour in the air) will increase. However, even if that happens, the extra heat will increase the temperature of the window frames, thus it is less likely that you will get condensation.
The real issue here is that all you are really doing is exacerbating the problem and transferring even more heat (ie money) from the inside of your property to the outside.
Typically we'd have the temperature around 20 degrees. Somehow, accidentally, the temperature got up to 24 degrees inside, and that encouraged the condensation to disappear. No other changes. However, that’s too warm for us, and now I also understand why most of my neighbours don't have the same condensation problems - they’re just overheating their homes.
3 UPVC secondary internal cladding:
I stuck UVPC extrusions to the internal surfaces of the aluminium frames. This almost worked. The reason it did not 100% solve the problem is that I used the thinest extrusions I could find, and they were only about 1mm. For all but the coldest days this solved the problem. On the coldest days we got a little condensation on the window glass, and on the internal UPVC.
So, as this was an experiment in one room, I am rolling it out to the other rooms, but with thicker UPVC extrusions, which I am hopeful will solve the problem completely.
Now, I expect that some people will start arguing about there being a problem with water vapour coming from some source within the property. I believe that is not the case, in fact it is most likely that relative humidity in the property is probably on the low side of normal (ie it always seems very dry). However, the problem is that the window frames are significantly cooler that the room temperature (ie the room temp is 20 and the frames are in the range 10-12) - I don't think you need to be Einstein to work out that condensation is going to occur on the window frames well within the normal range of humidity.
Condensation on the frame of new aluminium windows
All I know is I'm taking my Volvo back to the dealer right now because the windows steam up if I've been sat in it for a while, gonna tell them they must of fitted the glass wrong but being Swedish and from a cold country you'd think they'd know what they were doing wouldn't you?
www.diynot.com
1 Stop breathing:
