Looking at the overall shape of the gate, it looks like it's been bent out of shape.Looking at the marks on the ground I would suspect that the post is no longer vertical. The weight of the gate has pulled it in the direction of the red arrrow.
The top hinge is on upside down and weldedI know how you can weld those hinges, but I can't see it. the top one looks like it has a bolt with a hex head. Please post some pics of the hinges and the welds.
I think probably the gate has bent with children swinging on it.
Is the post concreted into the ground, or bolted to the wall?
Yes it is slightly one of our sons did it many years ago but it has also droppedLooking at the overall shape of the gate, it looks like it's been bent out of shape.
Thanks , used a ratchet earlier and it has lifted it but also bent the side of the gate near the black postit is not of very solid build
I think you could pull it back to shape with a long piece of threaded studding, diagonally, and tighten the nuts on the ends, or a turnbuckle and cable.
for a trial, get one of those orange nylon ratchet straps, as used with roofracks, and pull the sagging bottom corner towards the top hinge fixing on the opposite side.
Thanks, we did that earlier with a spade under as well , it wouldn't lift it enoughThe gate has dropped due to it being made with no diagonal brace.
Length of timber under the latch side and lift up.
Andy
Thanks, the gap isnt big enough to get a car jack under whatever position we open the gate toI'd try to find a way to get a car jack onto that. You mentioned the latch bending, but you would jack it with the door partly open, not closed inside the frame. Maybe some bits of wood through the holes just below the latch and then jack onto that.
