The Zinc flu is so nasty, I shivered for a day with that one, as well as needing 10 blankets to sleep!.......especially if the material is galvanised - nearly topped myself with that one back in the 70's
John![]()
John![]()
Its good to have a mask that the hood part comes back over the top of the head as possible . It helps shields light coming from behind which reflects off the rear of the lens and you cant see sod all.cheers all
I'd be doing most of it (if not all) outdoors, so light should not be too much of a problem.
I'll check response times, and have a look on Welders Warehouse too
If the battery is solar charged and not exposed for a long time this can happen so if you haven't already done so, stick in the sunlight for a bitMine is a Speedshield V, without the grinding facility.....if I look at diffused sunshine it starts flickering.
I haven’t welded for over 12 months now so I’m wondering if it needs replacing - its many years old now.
John
You need to go back to lidl and buy the mask, an automatic mask makes like sooooo much easier
so by this point I think I can weld a whole bridge together over the Trent in an afternoon at this rate![]()
Thanks John - the tint is green before you strike and then once underway, I would say it's totally fine visibility, you can see the stick point 'bubbling' and i can see how far from the edge I am and roughly where I have been - but as I said before, I have nothing to judge it against as I only arc welded for 20 mins in 1981when a mate asked if I wanted a go. These new darkening masks are incredible, a bit like voodoo magic really. I was a little nervous for a while thinking 'how can this turn on quick enough to protect my eyes?'That helmet looks like a cracking deal......when you strike the arc, is the material still nicely visible? Pulling the arc slightly away helps to keep things lit up somewhat.
Try, using a piece of flat bar laid flat, starting at the end furthest away, strike the arc and progress towards yourself using the 'U' technique in a straight line. If the slag comes away in one piece then you are certainly getting there!
For two bits of bar laid flat, tack them together top and bottom, leaving a 2mm gap between them....this helps as a sort of 'prep'. Then weld an inch at the top, same at the bottom then turn the bars over and do a run in the middle - this can help with the distortion which will certainly come.
If my experiences are anything to go by, you'll have good days and bad ones!
Do keep us updated!
John![]()
