- Joined
- 15 Jul 2022
- Messages
- 110
- Reaction score
- 2
- Country
Hi All,
I hope you are well.
To cut to the chase. I have a roof with old school ridge tiles on the part wall that needs fixing before it starts raining properly.
I talked to the neighbour and I think we should be OK to proceed with the repair. It is not leaking on his side.
We won't be replacing roofs only repair it. I think considering he is a pensioner, it's a relatively short notice I do 60/40 split of the costs.
The funny thing is I have two local roofers who I wanted to chose from as they are the most responsive of all BUT one of them wants to fix the ridge tiles while the other insists on installing the secret gutter but I am sure during the inspection he suggested otherwise - a less invasive job, fixing the ridge tiles rather than a secret gutter so he must have changed his mind in the last 2 weeks.
I dealt with at least 12 roofers, 4 came over and 3 other gave me quotes based on the images.
The man who wants to fix the ridge tiles and use some Belgian tech in place of the mortar that apparently lasts much longer showed me that fixing a secret gutter if the roof is not replaced at the same time leaves a mess because they cannot match the tiles exactly in terms of colour and he showed me an example on a nearby roof. He also suggested to install some loft ventilation tiles.
The other gent told me that ridge tiles are pretty much illegal these days and this should be phased out. He also said that whatever is to do with ridge tiles won't last 4 years as frost will crack it open.
To be frank both sound professional and the man who suggested fixing the ridge tiles has twice as much good reviews. Both quotes are pretty much the same in the region of £1000-1200. I want to recomission my chimney for a log burner so they quote me extra ~£600 for that but this is a separate job that I want to factor in while they fix the chimney which makes a perfect sense and since they need a saddle scaffolding for work on the cowl they will do a better job on the chimney.
What do you think? What makes more sense?
