Undercloaking. Some questions.
29 Jan 2012
Dorset
Putting new undercloaking back after replacing sofits.
The undercloak boards are butted and not overlapped right?
The top of the fascia board is about 30mm above the top of the rafter, so the last bit of undercloak needs to kick up and rest on top of the fascia, right? Do I just fill the gap under it with a wood fillet? Or should I run the undercloak all the way down the rafter to the back of the fascia then put some muck in there and sit another piece of undercloak on top, resting on the top of the fascia?
Cheers!
Undercloak is on a verge.
That's eaves board or is it supposed to be plastic eaves protector draping into the gutter?
Either way, you need support fillets.
In my case this is a gable above a dormer.
So wood fillet on rafter, sit small length of board on that? (middle option)
