If your idea is to keep the wall as thin as possible internally, could you brace it in some way on the outside? i.e Coal bunker! or even just a gabion basket full or rocks?
Missed this, thanks for the response. I can easily do the thing 'blocks-on-flat'*, but that's more work, larger slab, and I wondered, overkill. Hence the question.
Had you considered just buying a glavanised dip tank and, if you couldn't live with its appearance you could still build a non structural wall around it, that removes any doubt as to structural integrity , waterproofing and creating a leak proof drain plug.
Yes there are preformed plastic standalone pond liners, it's a no brainer if you can find one the right size. All this talk of block wall lining is barmy.
