Many thanks gents, much appreciated. Would you say I am ok to get our Quartz worktops fitted and the plumbing side of things shouldn't be too much of an issue as I can still pull the dishwasher out.
Trouble is I need the sink in situ don't I? The sink is undermount, so I can really Plumb the waste in until that's in or would you start from the stack run the waste at a 1:40 incline towards sink by chasing out blockwork then its there for when you need to connectI'd get the plumbing sorted first, always easier when access is least restricted.
If you're unsure what height to run the pipes into the cabinet at and want to minimise the amount of waste pipework on show or you are fitting shelves and want to minimise the butchering then sit the sink with waste and trap attached on top of the carcase and then add the thickness of the worktop, that'll give you a rough idea of the height of the trap outlet. You can then run the waste pipe into the cabinet a little lower than that to give you room for adjustment.Trouble is I need the sink in situ don't I? The sink is undermount, so I can really Plumb the waste in until that's in or would you start from the stack run the waste at a 1:40 incline towards sink by chasing out blockwork then its there for when you need to connect
When DIY'ing always try to dry fit where possible to ensure everything is going to fit and it's where you want it before fixing in cabinets etc
Really good point about the supplies. Unfortunately they are already in and protruding through the top of the unit! Do you think it's worth removing the sink unit and lowering the hot and cold to come in through the bottomYes. Run from stack to sink location.
Leave waste stub sticking out of wall.
Do same with hot and cold supplies.
Drill holes at relevant points in backboard of sink carcass. Push sink carcass over pipes and back to wall and fix in place.
Complete rest of kitchen. Do second fix sink plumbing when everything is in place, from inside the sink carcass. Keep supplies as low down as you can in sink carcass to make it easier for you to 2nd fix as there's not much room with and under mount sink.
It's a blanco sublime 1.5 bowl granite if that helps, is there a waste connection that takes up minimal height for two bowls and a dishwasher?Its an undermount mate.
Won't be much room and there won't be much on show. Low down as possible and long hoses on the tap which will be fitted to the worktop behind the presumable belfast style sink.
