Socket is going to be hidden behind cupboard.
20 Jan 2016
I’m building a cupboard and there’s a double socket (on a ring) that’s going to be hidden behind it, which is a problem when it comes to maintenance and accessibility of that socket. I’d also like to take advantage and run a flex out to a new socket installed on the side of the cupboard.
I’m thinking that using wagos (as a maintenance free item) that I could simply join the ring and run a flex out to the new socket, however I’m unable to find a double blanking plate with flex outlet. Does anyone know if they exist and if that’s the right way to do it?
Converting the double backbox (fitted into insulated plasterboard) to a 1+1 backbox could be done, but then would I need to use a spur switch (which would also need means of access for maintenance)?
Thanks, Dave
Cut a suitable hole in the back of the cupboard.
Drill a hole in a blank plate and fit a gland.
Thanks, Dave
Can't cut a hole as a shelf needs to go slap bang across the socket, and shelf height can't be changed.
What type of gland did you mean? like just an open grommet with a tie wrap to strain relief the cable (not sure if that's allowable?) or a compression gland?
Wago's are only maintenance free when used with a suitable junction box, If your building a wardrobe why not lift the floorboards and do your join under them and then route up to new socket
Thanks for all your replies!
Normally I would consider making an access panel of some sort or removable shelf, but the cupboard is really small and I wouldn't like to be the one twisting my back at all sorts of angles to squeeze in there to check the wiring of a socket. Plus also the wires come from above and the floor is concrete so that's unfortunately ruled out too.
I didn't want to overcomplicate something seemingly so simple but it either seems the gland idea (which means the gland pokes out a bit especially when allowing not too tight a bend on the cable), or else I reckon change the backbox for a 1+1 and fit one standard blank plate and one flex outlet blank plate.
As I'm connecting just one socket radially I don't think a spur switch is required?
It's just a shame I can't find a double blank plate with flex outlet that runs downwards, as to me that seems the simplest option.
Get a thick blanking plate and file a slot in the edge so that the cable exits down/up/sideways to suit. neater than a plate with a gland on it
You could get a 4 gang grid plate, fit three blank modules, and one flex outlet module.
And use 2.5mm2 3 core flex.
Or if you only have the more usual 1.5mm2 3 core flex, use the grid plate, two blank modules, a 13 amp fuse module, and a flex outlet module.
