Hello, am I correct in thinking that having nothing between padstone and beam is ok for building control. And is steel shims and no mortar ok if needed.
Also as the gap between the top of beam and concrete blocks will need to be pushed in with a dry 3 and 1 mix, is 10mm bed with a few shims in there (to give instant support) ok or should it be thicker? Thanks.
