Hi all,
Looking to get a bit of a sanity check here. I have a new-ish (2017) build house, which is an Ideal Logic Combi C35 boiler, with 2-zone heating (upstairs and downstairs split). The wiring centre and zone valves live in the airing cupboard upstairs, mid-way through the house from the boiler. The two thermostats are wired (but battery powered) ESi ESRTP4 programmable units. Upstairs thermostat in the main bedroom, which is (unfortunately) south-facing and has no TRV, and downstairs thermostat at the bottom of the stairs, again with a rad having no TRV. It seems normal wisdom that the room with thermostat should have no TRV, yes?
Now, looking at future upgrades, it seems I should be looking in two areas - OpenTherm and Smart TRVs.
OpenTherm
This one is easy - modulate the heating flow temperature to avoid cycling. The hard part seems to be that our 2-zone heating complicates matters somewhat, with seldom few "smart" systems being able to run 2 heating zones and OpenTherm. I found EPH thermostats that claim they can, a few internet posts saying the Drayton Wiser system maybe can, and Ideal's own Halo system certainly seems like it can. The Ideal system looks like the easiest fit, as the boiler control can be fitted right next to it and so a very short, invisible, and easy fit run for the OpenTherm cabling as the zone control unit would go upstairs in the airing cupboard where the current wiring centre and motorised zone valves are. Other systems look like we'd need to run extra cables over cupboards and through walls as their control units effectively replace the wiring centre upstairs - this could be messy with the layout of the house. This aside, how much could I really expect to save with OpenTherm?
Smart TRVs
Again, very easy concept to understand. What I can't see is exactly how much energy saving I'd get from switching our system over to smart TRVs. It seems their concept is one of ultimate and fine control. This is great, but when I have 8 rads currently with TRVs, and packs of 3 heads cost £200, that cost is rising very quickly, even before getting the requisite receivers etc. This also doesn't take into account that I'm struggling to find a hard "yes" to systems that could control 2 zone valves on top of smart TRVs. So, it would seem to go to smart TRVs, I'd somehow have to bypass the two zone valves or somehow fudge them to actuate together so the house was acting like a traditional single-channel system. This seems sub-optimal.
On the surface, it seems I could make a bit of a saving (though how much?) if we got some kind of OpenTherm system in, but using Ideal's own Halo as an example, I'd be looking at about £350 or so, and that's before getting a GasSafe engineer to come and re-wire some bits - all of which I'd be happy to do myself, it's just the boiler cover has to come off to get to the electrical connections, so GasSafe it is. Looking at smart TRVs, it seems I'd be looking at a minimum of £600 before any required wiring or zone-valve fudging, again likely needing a GasSafe engineer to plumb into the OpenTherm connectors in the boiler controls.
I guess I'm just looking for any input from wisened members, or perhaps harder numbers as to what I could expect to save. It seems I have a ludicrously sized boiler for our house size (roughly 100m2), so I'm just looking to make the best of the current setup.
Thanks!
OpenTherm
Smart TRVs
Thanks!
