No need to add more air as the pressure rose to about 1.8 bar when heating was on.If its the actual pipe between the E.vessel and the main pipe then only a few litres (expansion) will move back and forth as the system is heating up and down over a fairly long period so wouldn't expect to feel any or much difference in temperature.
Did you have to vent air again to get these rads heating, if not then perhaps restriction /blockage somewhere, you might increase the system pressure by 0.5bar, if its hot and reading say 1.7bar just now increase it to 2.2 bar and try rads on their own again, its very strange that a 8M pump will only pump through these affected rads only when on their own.
The rads that are now working i added to the system of 15mm existing pipe work and each of the 5 rads has their own flow/return from the 15mm pipe work.
yes funny when all rads are off and one that dont work are turned on 1 by 1 the heat up then when i turn all rads on the ones that didnt work go back to not working??
