New rads
7 Jan 2011
North
Ireland
Hi
I have installed new rads with pipes running across loft then down walls to rads.
I took feed of 15mm flow/return and t'ed off for each rad.
The first rad is heating up fine but rest are not.
Pressure is at level on system and I have turned other 4 rads off unscrewed valves at top of each rad and open valves.
Couple of them heated then went cold again.
Any ideas?
I'd say it was air as said above. If the radiators are of a designer type then the flow could be on the wrong side.
That's the radiators I have installed
turn off every rad apart from just one of those thats not heating and that will force the air out the pipes then repeat for each of the rads not heating up
Tried this and yes radiator that wasn't heating did heat but when all back on again went cold.
How long do you have to leave the not working radiator open for?
