If it is fluctuating it is not DC. It is DC with added AC.
Battery--- switch--- lamp
Switching the switch on and off creates AC ? , I do not think so,
if currents are high enough the vibration may be audible.
I can't fault your comments and yes I wholeheartedly agree.Quite, as in a transformer, but the OP is discussing fairly normal levels of domestic current.
Normally, there should be no eddy currents induced, because of counter windings - a live will be matched with a neutral, or a phase with another phase(s) so they cancel out, just as they would if a transformer were to be would with a counter winding.
The fundamental issue here is there are two different worldviews of AC and DC.Battery--- switch--- lamp
switching stuff on and off absoloutely does create AC components in the current.
I think you've forgotten what the word 'component' means.There can only be an AC component if the direction of electron flow reverses
Probably the simplest method for me is to remove the 230v stuff and just use 12v. It will work anywhere and if I am on a mains hook up the battery will be getting charged.Something that nobody has mentioned yet, what is the liklyhood of these 2 cables being used at the same time?
In my experience of camping the chances of batterypower being used when mains is available is pretty slim.
