- Joined
- 20 Oct 2022
- Messages
- 11
- Reaction score
- 0
- Country
Hi all.
I am renovating my home and I would like to replace wooden spindles and handrail on existing staircase with a frameless glass balustrade. Finding a supplier to make the glass panels (c15MM thick, laminated etc) seems straightforward, but I am trying to figure out whether a 'channel system' can be actually be installed on my staircase or if, instead, I need to consider bolting the glass to the side of the staircase. It would likely be two glass panels on the down balustrade and one panel for the other.
Measurements
The balustrade from 2nd to 1st floor measures approximately 2230MM from point A to point B, or 3000MM along the handrail itself. The slope is 42 degrees.
The balustrade on the 1st floor (with no slope) is 2680MM along the floor length and around 1700MM along the handrail length
Is it simply a case of my builder making a deep enough channel for the channel system to sit in or is this simple a bad idea in the first place?! I would like to replace the newels as well.
Budget is max £3k.
Thoughts welcome!
Thanks.
Measurements
Budget is max £3k.
Thoughts welcome!
Thanks.
