...and wiring?
...and wiring?![]()
i have managed to power the thermostat via a wire connected to a plug done by a friend but thye heating seems to be on all timeThat may depend on the connections available at the other end of the cable.
For a simple solution, you could consider something like a battery operated Nest Thermostat E?
yo can not do thati have managed to power the thermostat via a wire connected to a plug done by a friend but thye heating seems to be on all time
Can I ask why the heating is all off now and works when I power the thermostatyo can not do that
Is this for the new thermostat? If so, you’ve given it its own power supply, which as per @ianmcd you can’t do that.Can I ask why the heating is all off now and works when I power the thermostat
It on a a fuse switch when I turn that switch off it power of the whole lot programmer and allIs this for the new thermostat? If so, you’ve given it its own power supply, which as per @ianmcd you can’t do that.
If you turn the switch off,then that’s what it will do, but you said you’ve wired it to a plug?It on a a fuse switch when I turn that switch off it power of the whole lot programmer and all
sorry got it wrong my bad sorry been a long day he wired it into the fuse switch which controlees the programmer etcIf you turn the switch off,then that’s what it will do, but you said you’ve wired it to a plug?
