At the moment is existing flooring removed. Did some pipe works under the floor. So few boards near the radiators are up across all rooms. few other boards are slightly up. But planning to replace them as well to ensure flat.
Existing boards on the floor, looks good - flat mostly. Boards cut and removed for plumbing will be fitted again.
Will be doing a laminate flooring soon. How do i go about laminates ?
Have had multiple people come in and give a quotes.
1 has said, floor looks good. So can directly do underlay and then laminates.
Someone else said, do plywood and then do laminates to ensure longivity (I dont prefer this as some water pipes are all running so close to the bottom of the floor boards).
Someone said they only do quick step and wont do wickes laminates or the one's sold in selco.
Need some advise on how to go about ? Would like to have a stable platform and longivity. May go for 12mm lifestyle floors and 5 mm underlay that one of the installer suggested. Quick step are well over the budget.
