Hello all, I'm looking to install a shower into the house. Currently there is only a bath.
There is a cold water tank in the loft space which I assume mains pressure enters, with two outlets.
There is also a hot water tank on the same floor as the bathroom. Which is heated by electric immersion, and also by gas ( not central heating ) an old heating system that blows warm air into rooms via vents.
What type of shower would suit me best? I don't know if I can tap into the mains if it goes directly into the loft tank, although there is a capped mains pipe which I could use but it's a wide diameter pipe.
Would I be better taking a feed from say the cold bath tap pipe which would be gravity fed and using an electric shower with a pump for good pressure?
The drop between the tank and where I'd position the shower is only about a metre or so.
Many thanks
Many thanks
