As part of my ongoing kitchen renovation I just ordered an integrated cooker hood, which has a 120mm diameter output spigot.
Looking online for a 120mm ducting kit there only seem to be very limited options, I found these two:
1) https://www.manrose.co.uk/product/43077-cooker-hood-venting-kit-120mm-5inch/ (however they call it 5 inch, which is not really 120mm, but rather 125mm... Aso in the technical specs it says: "Hole sizes: 140mm hole for the 125mm kit.")
2) https://www.appliancesdirect.co.uk/p/eiqventkit125cowl/electriq-eiqventkit125cowl-ducting (this is actually 125mm but it says the following in the details: "electriQ hoods are sold with a plastic hose and a 125mm to 120mm adaptor. This kit includes a premium aluminium flexi hose, which provides a more permanent solution alongside the outdoor flap grille and fixings provided."
Any suggestions on what to go for?
Also, I need to make the hole in the kitchen wall as there isn't one, and option 1 for example says it needs to be a 140mm hole. Looking at core drill bits that doesn't seem to be a standard bit size either, 152mm seems more common. Can I drill a 152mm hole and maybe cement the gap?
