- Joined
- 4 Jan 2012
- Messages
- 352
- Reaction score
- 7
- Country
Hi Guys,
Probably a really stupid question but I thought I would ask - Ive got a 40mm waste pipe coming outside through my wall which I plan to drop down the wall. As I understand it I need to make all changes in direction roddable. Is it sufficient putting a tee on the pipe and then just attaching a weld access plug onto one side of the tee?
Also just to check - Im assuming if you can just pull the pipe out (this will be at the bottom) then you dont need a rodding point as you just stick your rods down the hole where the pipe is?
Thanks!
Thanks!
