Previous tenant painted over muck
5 Mar 2022
Sheffield
Hello,
So between the council (council owned property) and the previous tenant, someone has decided that you don’t need to remove pieces of food, blue tac or anything from the walls before painting them. There’s even streaks of paint, you can see where it was dripping down and eventually dried into that shape. No idea X what they painted with, must have been really thick.
They’re in really shabby condition. All of them, in every room…
What can I do?
I don’t even think wallpaper will hide how unflat the surface is.
If I intended to live here for a year or two I’d not care. But the location is ideal for my child to get to school. So I don’t want to move any time soon.
I'd scrape with one of these - screwfix scraper
Then sand then wash with sugar soap. Then fill and feather the holes with toupret fine surface filler. Only this, no cheap easifill.
Then sand and paint
Gonna be a long long time doing this
It’s the same on every wall throughout the apartment.
Bug does look nice tho! Wonder if I can buy some to install
Hello,
Sounds as if they know what they are doing. Probably council's decorators. Sand it flat and paint over is probably the easiest. The thick stuff they have used would give you the materials for flattening.
The problem may seem huge. If you divide and conquer, it maybe a lot easier. Concentrate on making one wall perfect at a time. Given time, the whole thing will be done to your satisfaction. I call the technique incrementalism and it's extremely powerful for getting difficult or impossible jobs done.
Get a pole sander.
Why? I had my flat done with easy fill. It seems ok. Will it fail?
The toupret fine filler, while only good for a mm or so of depth, is perfect for dealing with holes in paint and feathering edges. Most importantly, it doesn't peel off when you go over it with a roller, which easifill does when used in this manner.
In general, my thoughts and experience with easifill is - easy to sand however easy to dent. It won't fail however give it a year or so and wear and tear / knocks show.
It has its place, I used it extensively repairing damage from removing picture rails and above windows. It's cheap and easy.
For the stairs, hallway, dining room - nah.
