Hi all,
Looking to install a Magnaclean Pro 2 filter on my system, seems like a good idea with 10mm Microbore pipes!
Anyway before I pull the trigger I’m struggling to see where I could install it, I think I’ve ruled myself out DIY’ing this job now but would a plumber be able to fit it in the example below….
Above the boiler I’ve got not a lot of space on the return pipe to the roof (I believe the pipe on the right), it’s about 34cm but the pipe has a few bends as well rather than being straight.
Is there anyway to install it with some modifications or will there just not be room to service it easily?
In the airing cupboard with the rest of the pipe work it doesn’t seem much better, not even sure the return pipe runs through here…
I could really do with a filter but is it going to be possible without putting it on a flow pipe which I don’t really want to do.
Also slightly unrelated question…but what kind of setting on the boiler flow temp would be good on my WB Greenstar 24ri? Not sure if I’ve got it too high or too low at the moment but not much to go on right now to decide. I have had it on max a few times but I doubt that’s particularly efficient! Currently set as below. House with 15 radiators 3 towel rails.
Cheers for any help at all!
