Round radiator valves
1 Jan 2019
Hi on my upstairs rad the valves are round and not square so I can't adjust/isolate them. Have you come across these and how can I isolate the rad please. I'm not talking about the bleed valve. I mean the flow and return valve.
It's a Combi system.
Thank you!
Matthew
Sounds like you may have two lockshields. Why do you want to adjust or isolate them ?
Thank you!
Matthew
Do you mean the plastic caps (usually white) are round? If so, they're decorative and pull off. You should then be able to turn the valve stem, using a cap that engages, or failing that an adjustable spanner.
See photo thanks
Thanks I don't think it's that though
The spindle sticking out the top is now rounded Off ,it used to be square. Need a set of grips to close / adjust it. You should replace it.
Judging by the state of that rad, it may be worth thinking of replacing that too.
Thank you for your advice.
