I have been given a Hive Thermostat for Christmas and have been looking at how to connect it to our Atag IC36 Combi Boiler.
Though a 3-core cable runs from the boiler to the Honeywell CM907 thermostat, the SwL isn’t connected at the Honeywell. Not sure if it has come loose or was never connected?
From earlier postings I believe that I need to connect the existing L & N from the boiler to the L & N of the Hive and the SwL to the Heating On (Terminal 3 ) of the Hive. Is that correct?
As there is currently no earth connection, I am planning to replace the 3-core with a 4-core so that that I can earth the Hive. OK?
Thank you .
PS I have just looked at the Hive Receiver and though there is an Earth terminal it doesn’t actually connect to anything. Replacing the cable with a 4-core seems pointless.
Thank you .
