One of these:Is it for a bathroom fan?
Show us the front.
Why do you call it a 3Amp?
One might suspect the MIs - which way well have 'required' both a 3-pole isolator and a 3A fuse!What led you to choose this isolator?
Have a look at @bernardgreen s diagrams in the linked thread.but we didn't seem to get to the answer of how to wire it up,
That's the cause of much of the discussion here; regulations do not specify this type of switch (isolator), or fuse!Doesn't make any sense but regulations specify this type of switch so what would be the best way to wire this up?
So, at the fan isolator switch, can we assume your wiring is as in your web link?:my wiring for the bathroom lighting circuit, with a pull switch and extractor fan is on this link,
@banchee
So, is it for a bathroom fan? Yes
How many wires does your fan have? Using 3 core with earth 1.0mm
How many wires does your supply have? Supply to the bathroom lighting is 2 core with earth to a junction box, then 3 core with earth supply from the junction box to the isolator switch.
Does the supply come from a lighting circuit or some other circuit? Lighting circuit
Is the supply switched, for example by a light switch? Pull chord switch
What led you to choose this isolator? Manrose fan suggestion to use a 3a fused isolator switch.
