I am currently in the process of replacing the lighting in my hallway.
The existing light is a single fitting, which sits halfway down the hall, directly below a junction box (pictured). The light is wired to two switches in the hallway.
My plan is to
- replace the current junction box with a large wago box, and rework the connections with wagos.
- replace the lighting flex with 1.5mm T&E running to the LEDs
- daisy chain 5 of these LED down lights (manufacturer guidance is no more than 6 daisy chained)
- terminate at the last light on the chain
www.screwfix.com
The only issue I have is that, because the junction box is halfway down the hall, if I used a single run of cable for all lights, I would need to go to one end of the hallway and then double back (i.e. JB - light 1 - light 2 - double back past the junction box - light 3 - light 4 - light 5).
The other option that occurs to me is to replace the current flex with two runs of 1.5mm, one branch going to light 1 - light 2 and the other branch going to light 3 - light 4 - light 5
If there any reason that I cannot branch to two cables, rather than just use one run?
Any thoughts would be much appreciated.
My plan is to
Luceco FType Fixed Fire Rated LED Downlight White 6W 600lm - Screwfix
Order online at Screwfix.com. Integrated LED fire rated downlight. Fully dimmable with interchangeable bezel. Supplied with white twist and lock bezel. FREE next day delivery available, free collection in 1 minute.
