Daisy chain of LED battens with one connection point
23 Mar 2009
Cumbria
I’ve got some 5ft Luceco T8 Climate eco LED battens (link below), but they’ve only got a single pre-drilled connection at one end. There are no obvious knockouts at the top or other end. Ideally I’d like to drill an opening at the other end and feed a three core cable through to allow this light to be daisy chained to the next light without needing a separate junction box. Obviously I’d need to drill a 20mm hole for a new cable gland.
Are there any issues with doing this? I can’t find anything about this on the manufacturer’s website. I’m assuming that temperatures within the light won’t challenge heat resistant flex running through above the light fitting itself)
https://www.screwfix.com/p/luceco-e...-led-weatherproof-batten-2-x-24w-3900lm/946kr
thanks
From the pics on the website it looks like the opposite end is moulded to accept a 20mm hole and gland so I can't see why it shouldn't be ok
