I've been planning to put external door between conservatory and living room (the opening is 2.5m wide) and recently uncovered a concrete lintel with bowing brickwork. The latter is bowing downwards (see photos). I've noticed from upstairs window when looking downwards that the brickwork is cracked in a stepped pattern above the opening. The concrete lintel is approx 11cm wide by 22cm high and 226cm long. It does not show any signs of cracks etc. I've also checked the length of the bearing on each side and left side is 150cm with the right being 100cm.
Above the opening there is pipework that collects the waste water from a toilet and a shower/washing basin above into the stack next to conservatory. The piping is visibly leaking making me think this would be contributing to the brickwork bowing downwards. I would think however the main reason would be missing brick lintel.
My questions would be:
Shouldn't both sides of lintel be supported with at least 15 cm bearing each side with 2.5m long opening?
Isn't the right bearing of 10cm too short for such long concrete lintel?
Shouldn't the brickwork be supported separately with reinforced brick lintel?
Any thoughts appreciated.
