It goes off more quickly if you do that ...I always place unopened tubs of butter/spread upside down in the fridge until they are needed so that we know which ones are unused.
I don’t think you need to wash your hands.Wash your hands thoroughly afterwards obviously.
And when you have flushed & brushed, where does the brush go? In one of those little holders or just stood in the corner behind the cistern?
Either way, there is a very high chance that you will be transporting germs from inside the pan, (where they will eventually die and be flushed away), to an open air source that they probably wouldn't get to if you hadn't brushed. It's better to close the lid, flush the toilet, wait till the flush has finished, raise the lid and squirt a continuous stream of bleach all the way around under the rim then close the lid again.
When you flush a toilet there is a very fine mist that rises over the pan and settles on the surrounding areas. So, with the first flush, and the lid in the open position, you are actually spreading fine faecal matter everywhere including your trousers/skirt/pj's etc. With the lid closed the vast majority of this action is contained inside the pan. Once the flush is finished you then apply the bleach, as above, then close the lid. This also helps to keep bleach fumes inside and help destroy any airborne germs inside the pan.
If you do need to remove any staining from the pan it's better to wear disposable rubber gloves, a cleaning agent and use toilet roll as the applicator. This can then be flushed away down the toilet and the gloves put in a plastic bag/lidded waste bin for disposal in the general waste.
Wash your hands thoroughly afterwards obviously.![]()
You can't flush all the possible pathogens off.Still failing to see the point of bleach
What do you do in all good faith that, when you stop and think about it, might just be pointless?
Something you do "because it's always been that way", "you're supposed to", etc.
Me?
Is there any point putting bleach in the bog?
After all, you flush away the wizz, so nothing to bleach.
And after the solids, you flush, brush, then flush.
Bogs are made of basically impenetrable porcelain, so not a lot to stick anything to anyway.
And brushing is necessary to remove any bacterial films that may try to establish themselves: no amount of bleach will shift a bacterial mat.
Please don't derail this thread with:
- trying to get an answer out of..................
- getting a Gammon / Remoaner to .................
etc etc![]()
Watching telly isn't pointless.Social media and tales of what you have had to eat, drink, watched.
Theres a lot of that in here too
"Hang the sense of it and keep yourself occupied."ALL activities are basically pointless, you're all going to die.
My Mum's car is Elderly Woman Goes Mad....!Likewise. Rarely Washed Automobile helps me to remember my car's reg !
