Hello again, everyone.
It's been a while, but I have my next project that I would appreciate some input, please.
Background:
- First floor flat, with access to loft space.
- Internal shower room with no window, no external walls.
- Existing Manrose extractor fan is located in the ceiling above the toilet, venting approx. 3 metres directly upwards through a 110 mm PVC pipe.
- In certain weather conditions, mainly north wind, the fan will drip (brown) water onto the toilet!
- Occasional debris (rusty-looking particles) also drop through the fan and into the bathroom.
My neighbour in the next door flat replaced his fan, but also (I understand) replaced the vertical tubing as well.
I want to do something similar but can't help thinking I should use the opportunity to use a different type of fan (inline centrifugal), as well as relocate the inlet over the shower, where more steam is generated. Any condensation could be trapped and directed to the SVP via a running trap. Debris will also collect at the bottom of an S-bend/U-bend.
A couple of diagrams explain the current situation, and my proposed plan.
- I plan to use rigid ducting, not flexible ducting.
- The horizontal run between the fan and the S-bend/U-bend is approx. 1 metre.
I'm not afraid to spend approx. £100 on a decent air-shifting fan - I'd fit a jet engine if I thought it would help!
But questions I have are:
- Is the proposed pipe run too tortuous? Will the labyrinth restrict the flow too much?
- Should the fan be located somewhere else?
- Should I also add a backdraft shutter between the fan and the U-bend?
Any advice gratefully received, thanks.
Background:
