Wiring in induction hob and separate oven
23 May 2006
Southampton
Hi and good morning
I'm just about to install a single beko oven that needs a 13amp fused spur and an induction hob that requires a hardwired 32amp supply with cooker switch.
No problem with the induction hob, as I have a 32 amp dedicated supply already installed. My question is, can I use an existing 13amp plug socket below the worktop, with no on/off switch, but it's operated via a switched fused spur above the worktop?
I would put a new 2.5 cable into the cooker with a normal 13amp plug.
Obviously then, I would have two fuses, one in the newly installed plug and one in the existing fused spur.
Is this ok?
Thanks for robotik. Have fitted a duel outlet as you suggested, with 6mm wire from one outlet to the hob and a 2.5 cable from the other outlet to a 13amp plug socket.
Wired up the cooker with 2.5 mm cable and put a plug on one end, fused with a 13amp fuse. This way I have avoided 'two fuses' which would have confused everyone.
Why I didn't think of that....god knows :giggle:
Simple...;)
Cheers
Hi again
I notice robotik has deleted their post. I'm not sure why, but can only guess I've installed/interpreted their instruction wrongly.
If this is the case, I'm open to learn the best way to wire up these two appliances correctly.
Many thanks
It wasn't just the post that was deleted - Robotik itself, has been deleted!
It occasionally happens when, for example, a previously banned user has re-joined, with a different username.
That said, I believe the advice given was sound :)
