Ok so that was no luck. I tried chipping out little bits of the cement from the red bottom line and two courses above and didn't hit any black slate. The more I chipped, the more mortar kept coming out. How far into the mortar should I chip away at?
The internal floor is suspended with big gap underneath. If I was to take the floorboard off would I be able to see the dpc from the internal side of the wall? Where joists go into the wall?
