When using the hoover, often the cable is fully unwound and when we then drag the hoover beyond this point, it pulls the cable at the plug. Over time, this results in the outer sheathing slipping through the plastic retainer inside the plug and the single insulated copper becoming visible. Eventually, it leads to the L/N disconnecting within the terminals.
I've now had this happen twice, despite tightening the plastic restraining clamp in the plug as best as I can.
Evidently, it doesn't take much for us to end up in this situation. Is there a type of plug or technique I can use to avoid this?
Thanks in advance.
Thanks in advance.
