- Joined
- 17 Aug 2010
- Messages
- 2,746
- Reaction score
- 453
- Country
Not that I speak Spanish. But could it be 'ubicaciones'?
Do you have built-in (integrated) appliances- fridge, freezer, dishwasher, oven, hob, stuff like that?I think it refers to integrated circuits
The "picture" illustrates that which appears to be a "Type C" socket outlet.
Actually no. They're all free standingDo you have built-in (integrated) appliances- fridge, freezer, dishwasher, oven, hob, stuff like that?
It’s not silly if it’s solved the issue - it’s still an electrical item.This is gonna sound silly but I noticed a couple of plug ins, one to keep the cat calm and one as a basic air freshener. Both empty and still plugged in. They were warm to touch. I've now removed them and put the water heater back on an the last 15 hours have been fine
Did you ever figure this out?Has anyone used these water heaters before? I'm renting a home and the landlord insists on this heater as he installed one when we moved in. I've lived here 7 years and we're on our 3rd one. The first one died after a year by leaking everywhere. The second one lasted 2 and a half years but also died by leaking everywhere, and this current one we have abu0t 3 years I'd say and it seems to be now having problems. Electrical problems.
Last night there was a trip in the power, it was very late, but I checked each switch individually and couldn't find the issue immediately, but for some reason, when I unplugged the kettle, the power stayed on. That was fine. Now this evening, the power tripped again, and the kettle wasn't even plugged in. So, I unplugged things one at a time and rechecked each time. Strangely, this time, when I unplugged the robot vacuum cleaner, the power stayed on......but for just 5 minutes and then tripped again. At this point, I noticed that the water heater seems to be the only plugged in appliance that isn't on the same fuse as the rest of the sockets, and I found this unusual. Of course that might be perfectly normal, as I'm not an electrician or a plumber! But I had a hunch and I decided to unplug the water heater and then put the power back on, I even plugged the vacuum cleaner and kettle back in and boiled some water, and the power has stayed on solid for the last hour.
This suggests a possible fault with the water heater, right?
Should I run an extension cable to it and plug it in there and see if the system stays on? Or is it time to change this water heater as well. It's a FLECK water heater, cylinder shaped, 2 images attached.
Any help appreciated
