It'll be worth giving the X400 another week.
Do you have any tanks in the loft? An open vent setup will usually have 2 - one large header tank for hot water (150 litres or so), one smaller f & e tank for the boiler (20 litres or so).
What diameter are the pipes feeding the radiators? Ground floor rads- do the pipes come up out of the floor or down from the ceiling?
Flushing radiators is an easy (potentially messy) DIY job. Before doing that I'd be checking the flow and pressure at one or more rads (plenty of polythene on the floor and up the wall behind the rad, turn both valves off, loosen and release one valve from radiator, catch the water in a bowl. Once 1 end is dry, do the other end. Then finally with the bowl under one end of the rad, lift the other end.
The water shouldn't be too mucky (given recent powerflush and x400 dosing).
If you have a couple of bungs the right size, stuff them in the radiator ends and take it outside.
Back to your internal pipes. Bucket or bowl at one valve, turn it on. Water should flow freely and quickly.
Repeat with the valve at the other end.
Back outside to your radiator. Sit it correct way up to start with at a slight fall.
Hosepipe in the high end, turn tap on full.
Water should come out the other end, it shouldn't 'back up' within the rad. If the water is black or mucky, keep flushing til it runs clear. Start hitting the rad with a soft mallet, see if more crud starts coming out.
Finally set rad upside down, flush, keep hitting it.
