Hedge trimmer jonsered start and stops
22 Nov 2019
Got an hedge trimmer jonsered HT21 which start and stops.
I rebuilt carburetor but nothing has changed.
Lack of my knowledge but how this carburetor works as there is no primer bulb and only one pipe from the tank.
I can see petrol struggle to reach the carburetor but opening the tank after several pull can feel a bit of air pressure.
Any clarification is welcomed
Just a factor of some carb designs, Jonny........many chainsaws (Stihl, Husqvarna) don't have a primer or more than one fuel pipe, but of course the tank will have some sort of breather to let air in.
John :)
What do you suggest to check in order to get fuel from the tank to carburetor? Fuel filter seem to be clean and not sure what else to check.
John :)
See if you can find the tank vent......it may be in the filler cap or a separate part.
The fuel needs to be drawn up to the carb without any bubbles, so try with the fuel cap loose.
If no joy there, it’s a carb strip down I’m afraid.
John
Carburetor rebuilt.
Now start and idle for a little while but if touching the trigger dies.
Tried to reduce and increase the Low but nothing.
I got those on 1 1/4
Any suggestion?
Does the carb have an H screw? It's this one that allows the machine to speed up and it's usually a symptom of things being too weak so turn it out a fraction and try again. The usual setting is between 1 and two turns out from fully in.
John :)
No numbers
It's a walbro carburetor
I'd say that is a very early machine, somewhere around 2001 - 2003.
Anyway, I'd try to track down a replacement carb now and here are a couple of numbers that may help.
530035306 WT-221
530069682 C1U-W4 (This one is a Zama equivalent).
Try ebay, Amazon or whatever
John :)
