- Joined
- 8 Feb 2015
- Messages
- 241
- Reaction score
- 7
- Country
Hi all.
My lovely new internal door won't easily close because the inner/hinge-side edge of the door is too tight against the jamb, when it's being closed.
I want to trim a mm or 2 off the inner edge of the jamb, so the door can close properly, and sit flush against it.
I'd prefer to do it in-situ, and not to remove the jamb, as I'm only looking to remove a mm or so.
Was planning to run a router up it, removing a mm, and then tidy up the ends (where the router won't obv reach) with a bit of sanding.
Anyone got any other tips on how to do this easily?
The hinges on the door are definitely in the right position. They're old frames/jambs, and the previous doors had obviously been quite seriously altered to accommodate the proportions of the doorway.
