Mixing up cement for chamfer - cem 1 question
18 Aug 2008
Devon
Hi all,
I have an area where a wall butts up against floor level and would like to run a chamfer along the perimeter. External job.
Research suggests using cem 1 cement or tanking slurry with some added SBR and then to use a margin trowel to form the chamfer. Then use a sponge to work everything over before the mix properly hardens.
I'm having trouble finding cem1 cement, and I was wondering whether cem1 is just another name for ordinary Portland cement? It's difficult to find the answer.
I can find plenty of cem 2 cement which is a softer mix and I want this to be as hard as possible as it will endure a fair amount of weathering. So I want cem 1.
Thanks for any help.
If you ask builders merchants about Cem1 half will look at you as if your from another planet. Cem1 is classed as ordinary portland cement and cem2 has fly ash and other stuff in.
I came upon the problem you are having when using sovereign waterproofer which specifies cem1 or results could be catastrophic.
I found an Irish co did Prem cem1 but not sure where you will get it.
If you use a goodly amount of Sbr in your mix it should be fine for what your doing but don't use an enhanced cement like blue circle in yellow bags
You're a star mate. Thanks for the added information. I'm assuming a bag of ordinary OPC will do the job then. Yes I'll avoid the blue circle in the yellow bags.
