Connection a toilet to sewer.
26 Jun 2004
Hi
Looking to install a downstairs toilet. The sewer (not public it joins that at the bottom of the road) is about metre and a half down. I am wondering if I could connect the toilet outlet to the sewer using a drain ( that currently takes water run off from the guttering to the sewer manhole ) and divert the rainwater into a soakaway instead.
Chris
Hi
Chris
Are you looking to utilise a more local, shallower drain? Fine as long as the drain is a foul drain and that smooth running and/or rodding, is observed.
...and it's controlled work.(y)
You dont need to send the rain water to a soakaway, they can share.
Just ensure it is a Foul (or combined) sewer you wish to connect to. Connecting a WC or waste water pipe to a Surface water sewer is illegal and will land you in hot water with the Water Company when they trace it back to you!
As said, Building Control will need to be notified and may wish to inspect prior to backfilling any excavations.
